Dc 2.08.1
meangreengdub
When I download this and tell it to reboot, it says it will reboot into recovery but it never does. Also, when I reboot it into recovery manually, the zip file is not there. What am I doing wrong?
If I remember right, you are already rooted correct? What are you currently running?
Yes, I'm running DC 2.07 or whatever the latest DC rom was before he updated it last night.
BUT, now I got it to load but when I reboot the phone, it gets stuck at the black HTC screen so I restored my nandroid backup.
Not sure man. Did you wipe in between updates? I'm not sure that it is required, but it might help.
Yeah, I've not been following the DC ROM's lately as I have been running Fresh and am happy with it. Anyways, those of you that have been downloading DC ROM's...In big bold letters it tells you....
damageless said:
Wipe before flashing!
No need to wipe if you're going from 2.07 to 2.08, but you should be going to 2.08.2 instead of 2.08.1. Simplest way is to go to the DCupdater app. It will let you download the newest update and install it from one screen.
I don't see 2.08.2 available anywhere
The first boot on the updates (at least, 2.07.2 to 2.08) take a LONG time, sometimes a half hour. Can even be longer if you're using apps2SD. No need to wipe if you're using the updater (or even if you aren't).
Sounds like you downloaded the file using dcupdater. copy the file from the dcupdater folder on your sd card to the root and you will see it when you boot to recovery manually.
Really, a half hour???? I waited for about 10 mins and thought it was messed up.
Is it really worth updating? I'm thinking of not updating and waiting for the official 2.1 update. What things are new in the update?
It seems a bit faster than 2.07, and battery life is supposed to be better.
Changelog from XDA:
v2.08.1
-Tweak GPS + AGPS
-Added powertop - run dcpowertop from adb shell
-Cut down wakeups (should be a bit better battery)
**If you have battery issues before posting make sure you have calibrated
http://forum.xda-developers.com/show...postcount=3546
-Tweaked kernel and connection settings more
-Fix for rosie crash. Redownload skins.
-Fixed DConfig
-Zipalign of system now on firstboot & whenever a skin is applied. Please redownload skins.
-Bluetooth tweaks
-Potential market speed fix && Clear sense data issue were widgets missing on first install.
-.25 xda keyboard
v2.08
Changelog v2.08
-New DConfig tweaker tool
Theme Server
-New beefed up apps2sd. If any errors are encountered post /data/dcboot.log
-scheduler tweaks
-Working Friendsync
-Gallery3d fully working
-Newer XDA keyboard
-Fixed sprint NFL
-Optimized Even more/Cleaned up directories
-Connection tweaks
-Fixed fb sync
-Ring delay fixes
-More dalvik tweaks
-Potential audio fix & battery life fix
**First boot will take awhile if upgrading. Clears dalvik & fixes uids
If facebook sync doesn't show up in friendstream in friendstream press menu, settings, accounts & sync, facebook for htc
sense & turn on sync live feed.
You can view the changelog in the dcupdater. He also posted the changes in the 1st page of the thread @ XDA
Well I already have DC 2.07 or whatever so I don't want to wipe and lose all my settings so maybe I try flashing it again tonight and just let it sit for a while.
Maybe it's my imagination, but I think the newest version is slower in bringing up the dialer when I hit the "phone" soft or hard buttons. Once launched, the soft numeric keys are fast.
The stock ROM is worse because of the number lags, but it seems that Sprint, and mods, lose sight of the fact that most users want to use the Hero as a phone! It is nice to have all the doodads and improved app speed and eye candy, but I for one really, really want a working, responsive *phone* above all.
if you update through DCupdater, it won't wipe, and you won't lose your settings. Of course, if you update from DC 2.07 to 2.08, you don't really need to wipe, so you won't lose your settings.
So I updated and when my phone came back on, Sense has been turned off and I don't know how to get it back on. Any help?
go into "DCconfig" and check the banned apps. If sense is included in the banned apps, then uncheck it (and probably reboot). Otherwise, I believe you can clear your default button settings in one of the menus, so that the next time you push the home button it asks you whether to use sense or launcher.
ive looked quite a bit around the forum to find information on how to configure the dconfig app with this rom. anyone know of a post that talks about it?
thanks.
I can't get my downloads to show up in the Market. I did wipe the data first before I upgraded from 2.07 to 2.08.2. I restored my programs with Titanium. It has worked just fine with all my other updates.
Ok, I need some help. I was trying to reset the battery stats but instead I clicked "Fix apk uid mismatches" and since doing that, my contact pictures in Handcent won't show up. They show up when someone calls but no when I get a text. Anyone know how to fix this? I've rebooted the phone to no avail.
