Thanks, yes it definitely does, thank you. I just registered on their site but I guess I have to buy it from a re seller. Which reseller did you buy it from?I used Omnius Server, it's much cheaper.. and since I notice you are also in the US.. I will mention that they do have firmware that will leave your phone X10a, just as Davinci does. Think it was like $4.00 or so, as opposed to $14 or so at Davinci.
Hope that helps!!![]()
Thanks again.
For me it is playing safe - less chance of bricking my phone.Why are you guys paying for debranding? It's available for free
+1. With a couple of ways to do it you might as well attempt 1 of them.Why are you guys paying for debranding? It's available for free
Okay, I need help. I am not findinding a generic X10a, which one did you use?I used Omnius Server, it's much cheaper.. and since I notice you are also in the US.. I will mention that they do have firmware that will leave your phone X10a, just as Davinci does. Think it was like $4.00 or so, as opposed to $14 or so at Davinci.
Thanks![]()
I know there are plenty of ppl who've had success as well... but even with Android SDK tools loaded, my win 7 laptop wouldn't spit back my device ID. I spent ALOT .. I mean ALOT of time trying, but did the pay method in about 5 minutes, so IMHO, well worth it. Not arguing with you.. FREE is great
Just explaining why I chose and recommended the route I did.
Most of those replies stem from not reading the help links in the first post and what I've found is a lot, most of the time even, most issues stem from user error.X10iUser, The method you linked to is perfectly good, the reason I didn't recommend the method above is that, as you know, that thread is full of replies from ppl having trouble finding their device ID, java errors, etc.
OK, question: Has anyone in the USA using AT&T successfully debranded and installed 2.1? If the answer is YES, did you have any issues along the way? Is everything working perfectky, just like it was designed to do? If YES, any issues at all after installing 2.1?
Thanks, I need more "sorting out"http://dld.gsmdownload.net/m/leeae1.../X10/R2BA026/X10a_CUST_GEL_NAM1_1234_4820.rar
That one
If the direct link doesn't work look under :
Files >Flashes_> SONY_ERICSSON? X10 > R2BA026
It's the 4th one down.
We'll get you sorted yet!
The cool thing is once you are debranded, if SE has rolled the 1234-4820 kit out... you can then connect to SEUS and get the 2.1 update.. that part WILL be free.
Googling would have told you you need a program like Winrar or 7Zip to open them.1. The .rar file is no recognized as a compatible file.
So get one or the other and extract your files and try again.That wasn't exactly my question but thanks anyway.Googling would have told you you need a program like Winrar or 7Zip to open them.So get one or the other and extract your files and try again.
For those with an X10a who don't wish to pay for what can be done for free...As I mentioned the two files do not show up in the lest compatible files, mlm122 could you please give me some step by step instructions please for my 3 problems?
Okay guys.
Here is new X10flash for Firmware 2.1 Version (old 1.6 Firmware can not be flashed with this at the moment).
Windows 7/Vista Users should diasable UAC!!
Download Flasher: (Update 14.11.2010) GUI VERSION!!!
http://www-stud.uni-due.de/~sfanmakr/X10Flash/X10Flash-2.1.zip
HOWTO for Flasher here:
xda-developers - View Single Post - X10 Flash Tool - Always newest Version (14.11.2010)
You will see that there is a new Folder "firmware" the firmware files must be inside this folder!
Download Firmware:
X10i:
http://www.multiupload.com/G9TENJASZI Nordic Thanks to imugur and Reb0rn
Multiupload.com - upload your files to multiple file hosting sites! GERMAN
Multiupload.com - upload your files to multiple file hosting sites! CH (thanks to pippolino)
X10a:
Multiupload.com - upload your files to multiple file hosting sites! ROGERS (thanks to henh)
Multiupload.com - upload your files to multiple file hosting sites! GENERIC (thanks to BluechipJ & batman112)
Put the extracted files into the new "firmware" Folder and run the X10flash.bat
You have to wipe your USERDATA !! This is important, otherwise you will enter Bootloops etc.
Also be sure SEUS is NOT running! (But at least it should have detected your phone once)
THIS FIRMWARE IS ONLY FOR X10 NOT FOR MINI (PRO) or X8 !
But the flashtool should be capable of flashing all Xperia Series now!
If someone decrypts the Rom you can try it
Regards
Bin4ry
If you have more ROMS, just drop me a PN and i will add them to this post!
IF YOU HAVE PROBLEMS LIKE "Unable to Open Channel" please try this guide:
thanks aussiesausage
xda-developers - View Single Post - X10Flash 2.1 final & 2.1 Firmware (Update Flasher 14.11.2010)
2. Do I put the same .rar file for both the Application software and the customization files.and
3. Last but definitely not the least, after it recognizes my phone it gives me an error saying that my account is invalid. I am logged in fine on the site and through the settings.
Thanks for all your help.![]()
Yes, I am on AT&T in the US,debranded (and rooted). Tuesday I was prompted for the update, and upgraded to 2.1 through SEUS without a hitch. No issues so far.. just getting used to the differences in the interface between 1.6 and 2.1.
Still on the fence about debranding, eh Gunny?![]()
