What do the kernal updates do?
Do I need to update them along with the ROM?
Lekky - for 2.0g do I need to install the radio update? This woudl be the first Rom on my phone, after rooting as per your method.
I used ROM Manager and did the 2.0f update and found that Launcher Pro kept on FCing. Rather, it got really sluggish in the beginning - with me having to wait quite a while for it to respond (or give me the option to FC). How could I have avoided that? I ended up having to wipe it and reinstall everything, though I don't know if it was that which solved the problem (works perfectly fine now).
I'm wondering if I'm doing something wrong.
Tim
p.s. I really like that the buttons don't turn on the phone (except for the optical trackball push). Definitely the best part of the 2.0f. Otherwise, it seems the same to me.
