X10iUser
Android Expert
Just seen this posted at XDA and thought I would share it here...
- XDA
What you do with your phone is YOUR responsibility, I have not tried the above but the member at XDA says it works.
1. Root your X10i/a (See other posts)
2. Download Root Explorer.apk (market)
3. Open Root Explorer and navigate to /SYSTEM
4. Push on white button in the right top corner of Root Explorer (This wil change R/O in R/W).
5. Long Press on the file Default.prop and choose "Open in Text Editor"
6. Change in the folowing lines the XXXX-XXXX (scroll for firm codes):
ro.semc.version.cust=XXXX-XXXX
ro.product.name=x10_XXXX-XXXX
7. Press "Menu" and choose save and exit
8. Reboot your Phone
9. Open PC Companion
10. Choose Support Zone
11. Choose Repair (Your phone will be reset and will update with the newest firmware)
12. When done check your settings in de lock screen (menu-back-back-menu-back-menu-menu-back)
X10i CUST-NL GENERIC 1234-8547 (NL Customized)
X10i CUST-UK GENERIC 1235-7379 (UK Customized)
X10i VFE-NL VFE 1234-4593 (Vodafone NL Customized)
X10i TMOB-NL GENERIC 1233-7031 (T-mobile Customized)
For more codes see attachment...
- XDA
- Thanks to Bin4ry - X10 R2BA026 Nordic FlashtoolHi,
because i know that all of you want to upgrade to 2.1 as soon as they can i decrypted the Nordic Generic (Nordic Combined) R2BA026 firmware for you and put it together with flashtool.
Just start X10flash.bat. It will ask you if you want to wipe userdata or not (if you wipe userdata you will be factory resettet, if not your settings and programs will stay).
