this mod will work for this rom.
http://androidforums.com/admire-all-things-root/729905-mod-center-clock.html
Does the MMS fix change APN settings? I have nTelos and use a custom apns.xml to get data, will I have to modify this mms fix to match nTelos?
Since these are the instructions fix id say follow them and then apply your own APNsyes the mms fix is in the original post, flash it, download apn back up and restore from the play store, open it and choose the metropcs apn
Im pretty sure it does since the mms fix is the just the OA mms fix just slightly modified.
Please please please fix the bugs in 3.80! 3.75 is okay but the notification volume and the proximity sensor issues tend to get annoying. If it weren't for the endless force closes on 3.80 I'd be using it!
I have a release candidate that's almost done... I fixed the volume, some of the fc's, Switched to req's kernel, and fixed the proximity sensor.
Why is the RC2 link not working?
It's redirecting us to the forums :$
I put null as a place holder... Man I need some better hosting...
I can help you with the host
Ill need a dedicated host 24/7
Make a dev-host account?
I did it just deleates everything i upload...
Still hoping for the new RC soon. Keep up the good work man.
