My Triumph died after fully discharging.
I don't know if it has anything to do with running CM7 TG-Reloaded 03-01.
The last time I checked the phone, it was somewhere under 20% remaining (I don't remember exactly, maybe even under 10%), and a couple hours later, I checked it, and it had no power (I assume the battery was drained). I plugged it into the original charger, and no charge light came on, and it still wouldn't power up. I tried another charger and cable, and also tried powering it from my computer, but nothing made a difference. I've removed the battery for a few hours and put it back, with no change.
I can feel the lower part of the phone getting warm when I leave the charger plugged in for a while (with the battery in), so power seems to be getting into the phone.
Anything else I should try?
Do I need to get a replacement phone?
I didn't have any major issues with my current Triumph (with CM7): for example, this phone doesn't seem to have any light leakage issue, and I could get GPS lock in under a minute with GPS Test (slow, but mostly useable).
