Help Debranding phone..
extremejoe
evening guys
My dad has asked me to debrand his HTC wildfire because there's a ton of vodaphone software on it and the start up time is a joke
I have never debranded a phone before, so can you useful forum members tell me
what i need to debrand
after completion will it be as HTC made it? (factory settings)
will all the stock apps be on?
please provide me with any links to debrand and any help i could need
cheers :)
I have just successfully unbranded my wildfire using this guide. One quick question. When (and if) Froyo comes to our Wildfire can we still update it OTA?
Yes.
Branded handsets will have to wait until their carrier releases froyo branded.
Its only rooted handsets that won't be able to update OTA.
so maybe im stupid but i have made a gold card sucessfully and downloaded the exe file for the htc firmware.
But how do i the gold card to put the firmware on the phone??
You just have to have the goldcard in your phone. You MAY even need to have it in your phone when installing OTA updates too, but not entirely sure.
You download the RUU to your PC, connect your phone (think you need to connect to HTC sync with usb debugging on) and you run the RUU.exe on your PC. It detects your handset and flashes it.
evening guys
cheers :)
did you debrand your phone....successfully??????:cool:
I'm certain I've correctly created the GoldCard and when I ran the RUU, it detected my phone - screen switched to a black screen with HTC in white but other than that, nothing.
Any suggestions?
Cheers
Sorry but the link to that download, says it ain't a valid W32 application - which one from the Rom's site should i be using please?
All I can tell you is that I created the gold card as per the link in post 5 and downloaded the ROM mentioned. When I ran the programme it told me to use the latest version. I found the link I posted for the latest version and used it last Wednesday (10th). I saved the download, ran the programme and it did the job. Sorry I can't be of more help.
Evening guy's and girls, my first post here so be gentle :eek:
ive been trying to de-brand my UK Vodaphone wildfire, i followed the post below and it took a bit of faffing about to get working as i had a driver issue! :rolleyes:
after i sorted the driver out i finally managed to run the RUU and it completed its install, ive now inserted my new sim card and i keep getting sim lock come up :rolleyes::mad:
now i followed and did everything to a T, so i cant work out why i'm still getting this issue!
could anyone shed some light on the issue? was i meant to do the RUU install with out any sim card in it?
edit - i have a feeling i'm being a div and the debranding doesnt remove the sim lock!!!
1/Create a goldcard: How To: Create a Goldcard | TheUnlockr
2/Load the standard HTC firmware: Shipped ROMs
This worked just fine on our WIldfire, no more T-Mobile Web/Walk and when Froyo comes out, no wait for T-Mobile to do their messing around.
As with everything in life, you do this at your own risk...
Thanks for the reply Harry!
For some odd reason I had it in my head that it would remove the sim lock!I'm going to try give vodaphone a call today!:D
