Root decks reloaded question
G2435
okay question decks reloaded to install the zip and verify md5 whats the md5 and what do i do with it. Also do i have to use this recovery SMELKUSMOD Mason themed recovery or can i use my i think is aroma 2.3.3 something like that
One you have the rom on your sd card use an app like es file explorer. It should be included in mikg.
Open the app, navigate to the Rom on your sd card. Click and Hold it, go to properties, check md5 sum, and make sure the numbers match from your download link.
Basically this just insures you had a good download.
I usually don't check md5 unless something goes wrong
thanks im still going to give this mikg with underworld kernel to settle in before i decide and what about the recovery?
md5 is just a way to verify that you have a good download.
and no the recovery is not needed to flash the rom. it is just recommended. it is a good recovery that is based off of amon ra2.3.
okay thanks for the help either today or tommorow im going to change if this kernel doesnt work because i want one that saves battery and i heard mason with decks is good
says to wipe everything beside sd can i just wipe dalvik cache, cache, data
Basically best to do what the OP says if you don't want any problems once you flashed. You can try just wiping what you mentioned but it is likely you will encounter problems
Going from AOSP to sense and back you need to have an absolutely clean slate or you are going to run into a lot of issues.
Wipe dalvik cache, cache, system, boot, data, SD-EXT and SD-android secure.
Wipe them twice just to be sure
i already flash decks and it awesome but i didnt wipe sd android secure but i did wipe everything else
