Does anyone know the location of the default alarm sounds? I like the one named "light", but I want to extract the file, amplify it, and then put it back. I used to do this with my Env3 phone.
Well, it technically voids your warranty, but a hard reset removes the root permissions, so that's easily reversible.
It also opens your phone up to possible software attacks / unauthorized access to your data, etc. But if you're smart about what you install and install the Superuser.apk, you should be fine. The SuperUser.apk brings up a prompt whenever a program requests root access.
