Help Default applications...help!
sboggus
Member
Ok, I keep thinking this must be a newbie problem, but when you install an application from the market that is better than the native application, how do you make it the default and not have the native application run.
For example, I prefer Handcent SMS for text messaging. I specified it as the default, but whenever I receive a text message, I get from both the default messaging app AND Handcent. It is annoying receiving it twice. Many apps are like that where it prompts me which app to use even though I specified as default. Am I just stupid or is this just the way it is. Sprint knows NOTHING about the Moment and has been no help whatsoever!
Help please???
I kept Handcent SMS too...
I just went into the default messaging app's main screen: settings > notifications and turned off the notifications.
Best thing for both of you would be to go into your default text message app and hit Menu > Settings > Notifications. Uncheck that and you shouldnt get double notifcatins anymore.
Just open the app > Menu > Settings
From there you can disable the native messaging application's notification and only receive Handcent's, provided that has been enabled within Handcent's settings of course.
That only turns off the notification in the status bar. The actual text message pop up still comes through messaging as well as the pop up for Handcent unless i am doing something wrong...:confused:
The Android platform is so new that things like this will need to be brought up to the developers so they fix it in future releases.
Does anyone know how to clear the defaults for the stock messaging app? I accidentally selected to use the stock messaging app as default instead of chompSMS, and now I can't clear it.. Help?
The answer to this prob is go to settings>applications>manage applications then find the stock messageing app and go into its settings and click clear default
