I also use Go Launcher and the only time the default option comes up is after I have installed the app, started it and then restarted the phone.
Press the home key so it can take you to the default screen.
Press on the menu key.
On the little pop up select settings
Once on the settings select applications --- manage applications .
Select all tabs
Then scroll down till you find Launcher App labeled as Sony Erricson Home .
Select this Launcher and scroll down
See where it says launch by default. If it is highlighted press on it, this is for the stock launcher is not the default. Tap Clear Defaults ...
Now press the home key, you should see the pop up asking you to pick your default launcher and now select Go Launcher ..
Voila![]()
