Willie Heckerslyke
Member
Couple of Q's if anyone can help me out here....
For some reason, the default music player doesn't show each individual mp3's artwork that's embdeded into the files - but I installed mixzing, and that does do it. Was wondering which is the correct tag ID to use for the default music app as this is could possibly be the cause - I've looked at my mp3s and they're all tagged with (ID3v1 ID3v2.3 APEv2) - all done in 'mp3tag'.
I have some of my music in folders; 80s music,90s Music etc, full of individual songs from lots of different artists so like to use the seperate artwork for whichever song I'm playing, so I've tagged them all accordingly, and as I said 'mixzing' displays each songs art just fine - but the default player seems to pick 'one' of the songs in the folder, and applies the one artwork for everything in that folder. Why not just use Mixzing I hear you say....!
Well it's not perfect either... there doesn't seem a way to re-order playlists and this is something I tend to do quite often.
One other thing.....if I create a playlist and save it, where is it saved to exactly...I can't seem to find it anywhere on the SD card!!
Thanks very much for any info or advice
)) .... I was on the i8910 boards like you and decided to get the Desire after reading about it on there!
