Default ringer location
JLeslie
Does anyone know where the location is for the ringers that come installed on a Galaxy Nexus? I use OI File Manager so I can view pretty much anywhere I want on the phone. I found them on my old HTC Hero, but I haven't located them yet on my new GNexus.
I'm assuming their fomat is such that they could be used on another Android phone.
i believe they are installed in the system files.
in order to access the internal system files you need to root, and use an app such as root explorer to view those files.
other than that you cannot see them.
unless someone knows another way to view system files
With OI File System I was able to see everything on my non-rooted HCT Hero (Sprint), or at least I thought I could. There was a lot of stuff I saw that was not on the SD card. The GNexus is laid out differently and while I easily found the Ringtones folder, I don't see anything in it. So the default ones must be somewhere else.
