Help Delete 800 bookmarks on droid at same time?!? Help!
twiy06
I ruined my droid!! :(:mad::eek:
I stupidly imported my firefox bookmarks into the droid and didnt realize that there would not be folders.
So now i have 800+ bookmarks in my droid!!!
How do i delete them all. I realized i dont need all my bookmarks on the droid.
Please. Help!
Wow :eek:
I don't know a way to Batch delete them so I suppose a factory reset may be your Fastest bet.
Anyone else have any more suggestions though?
Please. Help!
did you try going in the browser settings -> advance setting -> reset to default?
I tried restoring to default. it doesnt wipe the bookmarks!
I tried going into the phone using a file explorer and navigating to ect/bookmarks.xml but i cant edit or delete the file.
Is there any way to edit files on the phone like the bookmarks.xml file?
You can try this.
settings > applications> manage applications > menu > filter > all >browser
clear data and cache
might clear bookmarks no idea
I love finding old answers...
I just tried importing my bookmarks (with MyBookmarks, free on android market) into Dolphin. I have 1600 bookmarks. Yes, I know...
Anyhow, I didn't find them. Tried 3 times to re-import them. No good. Then I remembered that they probably showed in the stock browser. BINGO! Almost 5000 bookmarks. :eek:
You saved me a TON of 'select - delete - confirm deletion.' Thanks!
Now I'm off to pare down my bookmarks and try it again. :)
Dan
Yeah its great.
To give you guys an update....
I use foxmarks in my firefox to sync ALL my bookmarks between my desktop and laptop.
I love it.
Furthermore... to fix the issue of bookmarks on my Android...
I just bookmarked the Foxmarks page on my android. So now if i need to access a bookmark off my desktop... i just go to the foxmarks website on my android. That works wonderfullyyyyy.
Hope that helps
