Help Delete Search From Maps
Stop stalking people and you wouldn't need to, ya creeper.. :P
Try going into manage applications -> Maps -> Clear Cache.
Search comes up with a lot of misspelled crap.
Clear Cache is not highlighted.
Clear data is, but not sure if this is the right thing to do ???
This will clear all files, settings, accounts, databases and so on !!!
can clear it, may have to resign into latitude if you use it.
as a new member I was about to post the same question when I found this thread. I cleared the cache and still have all the previous searches listed. Tried powering off and rebooting, but that didn't help. so clearing the cache on Maps does not delete previous searches
Have to clear the *data* not cache, and there is a clear search history option in the settings too.
I finally found The Solution to clear search history from maps! When you are about to search and you see your previous search results, scroll down to the bottom and choose "Personalized with my places" from there comes new menus where you can see all your previous search and destination results. So just pick one by one and hold until you get a popup menu where you can delete from. I just did it and deleted all search results :-) all that clearing cache and data does not delete your search results.
