Is there a way to delete all of my images from my gallery without selecting each one? I have soo many pictures and that would take forever..please help I am running out of storage space lol
I know that Astro File Manager has a "Multi" (multi-select) option that allows you select mulitple files at one time while scrolling through a list of file, and then choose what operation (like delete) you want to perform on the selected items.
It has a toolbar at the top of the screen (you can turn that off, too, if you want) with a "Multi" icon that you would select after navigating to the folder/directory that contains your files.
Then, scroll through your files (it should produce thumbnail images on the left-hand side of the screen if you are in List view mode), selecting the ones you want, and then either press the desired function on the toolbar, or long-press your last selection and choose an operation.
