Once it's available, could someone kindly deodex and upload the newest ota update? Thank you kindly
What does the new update do
I updated dont see a battery dif at all
I was using d but then again i sit at a pc all day for work so my phone gets extremly light use so i prolly wouldnt see it
i got the next 2 weeks off work
Ill post the base deox tomorrow
I'm on the new update (e). I know that there is a deodex on here now can I use that one or do I need to wait for yours ?
if you use the other one it will be whatever version he deoxed it at ;P i think it was C but im not positive. ill get mine out tomorrow after work some time ;P
I will wait for new version. I'm new to this whole root thing so I guess I can root tonight flash it tomorrow. What exactly is deodex? Is it based on stock or theme is stock what not. My mission here to make motion more like Google intended android to be and rooted I can make like a jelly ICS idk its thought I'm working on. Thanks for help!
Plan on it after work. its 7:43 am ill be home in about 13 hours so ill upload and post it then![]()
