Root Deodexing Question
BankZ
I've been playing around with a few ROMs. Right now what I am doing is installing the black theme to Deodex, then installing the theme. Its kind of a pain. Is there a way to Deodex without installing a theme? Or at least is there a more mild theme?
I know I could Deodex and create a backup. Its just another step I would rather avoid.
I thought I had to deodex before I did a custom rom. Is that not true?
Yes but not truly...like I said most but not all roms cone pre deodex...just look in the instructions or guide that the dev posts about the suggested rom and it should tell you or post a question about it in the thread ...if it is pre deodex then no need fir 928 or manual if it isn't then you will have to deodex yourself
