riki1kenobi
Tom, welcome mate, yes a lot of questions have been asked and yes there is a search function but sometimes it is easier to just ask a question
I'm sure you have now read the FAQ's, but IF you or anyone else has this problem then I suggest you recalibrate the battery.
This can be done by following the XDA method (which is a bit long winded) or follow the method I use which is to charge to 100%, then remove from charge and IF the % drops off within the first 10-15mins put it back on charge to 100%. After doing this you should get a full charge every time you charge
As a side note to this, I would recommend NOT leaving the phone charging overnight! I have found that when constantly charging overnight you have to recalibrate the battery again
My phone charges in a couple of hours, so I charge it before I go to bed and when I wake up it is usually either still at 100% or around 97% (depending on what I have running).
