mine wont switch on properly at all now
restarts a few times then does nothing.
if i do a hard reset, what will i lose?
wow that's not good at all.
should i contact HTC directly then rather than orange?
you got any contact details?
cheers
I've been tearing my hair out with this problem for the last couple of weeks, it is so random, I could be sending a text, reading a book, or just speaking to someone and the handset just switches off by itself and reboots. The problem is over the last weekend it has started doing it over and over again for about an hour without me even touching it, I just sit there and watch it doing it! I have tried everything, taking the battery and sim card out and leaving it for an hour. Trouble is it is so random and works fine for a couple of hours or so and then wham it does it again. I am heartily sick of this phone; I went back to T-Mobile yet again! and they gave me a replacement battery to see if that made a difference, in other words they haven't got a clue either. We'll see what happens this time but one thing is for sure if it isn't right this time I won't be buying another HTC mobile or recommending it to anybody ever!
It's most probably due to installation of some kind of "Task Killer" app, or apps like this. You have to send it back to HTC. So I experienced and got so frustrated. Then I phoned HTC and they arranged to collect phone from me; they took it back and returned to me after fixing. It works perfect now.
Is you screen 100% clean?hi guys/girls,
I have mine 4 days now and it sometimes rebooted or is just not responding anymore, if you touch the screen on the right side the left menu button is pressed like it is not synchronized anymore. also upon replying to a text message sometimes i can put my finger 1 cm above the screen and it starts following my finger and writing all kinds of unwanted letters. Like I have elec. in my fingers.. also some of the screens just start to flicker up and down and then only thing stopping it is putting it into standby.
anybody had this/ I am thinking about having it replaced while I can.
