hi all ive had my htc about 8 months now an had the problem for such a long time and its really getting on my wick!!
what happened was i phoned a friend a while back now and put 141 infront of the number, later i sent a tex from just clicking on the number in my call log and sent it i forgot i put 141 infront of it so it come up with this message
if i press cancel or save it just takes me back to the message if i try and correct the number it will for that one message then when she replys it does exactly the same again and comes up with the same error
so here is a sequence of what the phone is doing
i click the contact and send a message and it sends to the right number then she replys
when i reply to that message i get
if i click my message and press message details it shows me whats wrong the phone trys to reply to this number instead of the one i sent the first message to
ive tryed deleteing the contact and deleteing all my contact cashe and checked my gmail and stuff to make sure the number isnt saved there
so can someone point me in the right direction on what to do !?
thank you
Chris
thank you
Chris
running out of ideas it must be stored in a cashe somewhere because even if she tex's me and i delete her from my contacts when i reply it still puts 141 infront even though i dont have the contact saved!
