Help Device is heating up very fast
Narek
After firmware update (from 2.3.3 to 2.3.4) I notice that device is heating up really fast. Its normal or not?
I just find that SGS2 doesn't have CPU temperature sensor and we cant see the CPU temperature.
I hope they will add it on the future firmwares.
*#*#4636#*#*
Battery information
Temperature is in there.
However, I have installed Battery Solo Widget. Very handy. Shows battery percentage, and if you click it, it shows the temp in degrees C of F (configurable)
*#*#4636#*#*
Battery information
*#0228# its another code for battery information.
But I dont know does 30-40C temperature normal or not?
It depends on what the ambient temperature is. Mine is idling right now at 20C, but ambient will only be a degree or two above that as outside air temp today is in the low teens with a strong W wind.
Its a firmware problem.
On 2.3.3 phone tempreature was 20-30C, after upgrading to 2.3.4 its 30-40C.
Although there are many people with 40-50.
