new optimus
Android Expert
Are you sure the MSL is correct?hi, I have been trying to access my sph-m820bst through CDMA WS for several days to no avail. Every time I try to put it in DM regardless of rom (CT MOD3.8, HalfAssRom1_0, 187MoD-HoneyBread6) it fails to accept the MSL with an error message saying "modem exception occours". It also randomly reboots and dialer hangs when dialing. Thinking it may have something to do with the custom rom, I have spent the last few days searching for a stock rom but, all of the links posted in "all-things-root" thread are broken with the exception of the FF18-rooted, but the file is unflashable as far as I can tell. Im only using the phone for a doner phone, so the random reboots really don't matter that much to me unless someone thinks it may be a symptom of a larger problem. Any help provided would be GREATLY APPRECIATED! Thanks
The MSL and other NV items are not part of the rom so the rom you are using is not likely to be a problem, the zip files, FF18 and such are not flashable they are to be used with odin, the phone needs to be in download mode.
If you want to use the phone for a donor the best thing to do is use QPST and use the file explorer part of it, open the nv items and pull out item 466. Then using winhex or another hex editor read it.
