Difference between GA10 and GB08
Not sure yet man.. Ota leaks don't have an official change log. I don't believe it will be much different than ga10 or the other 2. I am going to wait to try it until the issue with losing root is fixed and the repack is fixed..
I'm sure it will be nice tho as always
Ok so im on ga08 and wantee to let u know what I think
Not muxh if anything looka different but it is noticably faster and snappier. Connection is better. I'll update if i find any thing
I didn't expect any big differences in the UI. There were only a couple small changes going from FL04 to GA10. The only real differences I noticed was in performance.
The corrected One Clicks are available now :D
But I would suggest Dan's deodex. Unless they now have deodex on sextapes link. . If your on odex you can't flash any mods. Td ported his ga10/fl16 mods to work on gb08. Sooo
I usually give the stock rooted one a full run to see how I like it before thinking about a deodexed one.
I am running on GB08 as of today. most of the differences are internal. It does have a newer version of visual voicemail. It's data performance is like GA10 (which makes me happy).
I have the GB08 from SXTP site and yesterday installed the SGSIII v5 deodex GB08 per their instructions. I have done a benchmark of both and the SXTP consistently benchmarks a lot higher (10K range GB08 vs 7.8K range SGSIII). I even reinstalled the SGSIII from scratch and still the same. Anyone have any ideas or does it really matter.
You are comparing an odexed ROM to a Deodexed one. The deodesex one allows for easier mode and themes, but pays a speed penalty. Also, the touched by sgs3 has extra effects goodies in it I would imagine, and tweaks to settings will shift performance to make some things better at the cost of others.
on every other stock rom, you can call directly from sms inbox, but that option was completely left out, you cant even copy n paste the number to your dial pad, its either ememorize it or write it down!! Shidd i bought my smart phone so i wouldnt have to use my mind!!
I have no problem doing a copy and paste to my dial pad.
That's the trick though, you HAVE to use your mind to use a smart phone...
I found another minor difference. When doing a SCRTN reset the GB08 build will ask you for your MSL before it will do it. Prior versions wouldn't ask for it. I think it is a little overkill, but it does prevent you from doing it by accident. I am guessing it is a security measure to prevent harmful hidden dialer info on a malicious web site. FK23~GA10 would just up and do the reset on completion of the dial sequence, Stock FH29 would just wait for an ok to be pressed. The MSL query follows what the prevail would do.
