iamloco724
Whats the differences between these apps and also is anyone having issues with either one on there droids
One thing that I do not like about handcent, and if anyone has a solution please tell me.
I'm using the Motorola Droid and Open Home.
When I get a new text message on the notification bar I have the original message icon telling me I have a new message, AND handcent. When I slide out the notification bar and click on both to read (both lead me to the same place of course) and when i close out the notification for the original message is still there it will not go away unless I click clear, any idea??
The big difference is that Chomp doesn't (or at least didn't a few weeks ago) support MMS messages.
Can you only do bubbles in chomp?
The only problem I have, really, is that the virtual keyboard overlays a little of the bottom of the handcent pop-up window. I'm using the HTC keyboard on my Droid, though.
To fix this simply go to your the messaging system that was default on the droid and go to settings- notification settins- notifications and make the box unchecked so that it wont send you notifications through that messenger only through handcent. Then go to handsent- settings- notifications and make it so when you hit the back button it marks the message as read. I had this problem at first too and quickly figured out that this phone is smarter than me.
