evofrompre
Can Can anyone explain the difference? Which one should I use if I want to be on wifi?
Wi-Fi Direct allows Android 4.0 (API level 14) or later devices with the appropriate hardware to connect directly to each other via Wi-Fi without an intermediate access point. Using these APIs, you can discover and connect to other devices when each device supports Wi-Fi Direct, then communicate over a speedy connection across distances much longer than a Bluetooth connection. This is useful for applications that share data among users, such as a multiplayer game or a photo sharing application.
does anybody know how to get wifi direct to connect to a ps3? I am completely stumped
How does Wi-Fi Direct work?
Wi-Fi Direct device connections can happen anywhere, anytime - even when you don't have access to a Wi-Fi network. Your Wi-Fi Direct device will signal to other devices in the area that it can make a connection. You can view available devices and ask them to connect, or you might receive an invitation to connect to another Wi-Fi Direct device. When two or more Wi-Fi Direct-certified devices connect directly, they have formed a Wi-Fi Direct Group, using Wi-Fi Protected Setup™ and the latest Wi-Fi security. Now you can get started doing all the exciting things that Wi-Fi Direct enables!
I have a WIDI capable TV. When I am looking at a video or picture in my gallery I can select more then select player and see the TV. When I select the TV, what is on my phone immediately overrides what is playing on the TV and displays perfectly including sound.
I don't see this as the OP' question. I believe that will take some application development.
Bryan
