Ever since I installed GB there has been an icon next to the 3g icon that is two grey arrows going in opposite directions in the shape of a circle. Does anyone know what this icon is??
6. If you're having Sync Issues After flash you need to Go back and do a Factory Reset in Stock Recovery. It helps if you do it multiple times. I usually do it 3 or 4 at a minimum.
I'll try to post a picture of it later, but it probably is the sync icon. Anyway I've had GB installed since last night, so will it just go away eventually.. or should I go ahead and do a factory reset?
And on a completely unrelated note, is there any news on some GB roms yet?
I had the same issue after a blanket restore of "all apps plus data" through TiBackup... it would not go away. If i froze contacts sync in TiBackup it went away but I just did a factory reset through settings and when restoring my apps through Ti Backup I picked "restore missing apps+data" and the problem went away.
again nothing definitive, just my observations
If it looks like the circle/arrow icon in my notification area it is the "sync" icon.
I restored all apps plus data and didn't have a problem.
Def OT but, I see you don't need your mom's name there, but looks like you maybe need a memory jogger for the wifey??![]()
I got it to go away by freezing contacts sync 2.3.3, but I don't want to freeze it permanently. Does anyone know of a way to get rid of the sync icon that doesn't require a factory reset? I don't want to spend another couple hours getting everything how i want it on my phone again.
After I applied the newest GB file that was posted today mine went away!
Its a reference to the new deodexed one I think.Where's the new file?
I'm pretty sure its facebook trying to sync contacts causing the problem.Its a reference to the new deodexed one I think.
I tried using it but for some reason all my contacts were f'd up, so I just nandroided back to the one with the sync icon problem. I'll try again later I guess.
