Need some advice from everyone here. My DINC seems to be overheating alot lately. Checking System Panel I see temperatures as high as 109.
The symptoms are as follows:
- when using to browse the internet, check Fbook and do email, continually for 30+ minutes - temp 102
- charging on Verizon Auto Charger - temp 109
- GPS for 2-3 hours - temp 104
Have brought this to Verizon's attention 4 times. Each time it was noted, I was told that they could not recreate it. Finally, after it getting to the 109 temp, I called and was told take it in and tell the store to exchange it.
So, my questions are....
1 - has anyone else seen temps like this? Is it normal?
2 - if they take the phone and exchange, I lose all my apps, correct? Is there any way for me to get them to the SD card prior?
3 - do I try to get a different phone altogether?
4 - Any other advice/opinions?
Thanks.......
Thanks.......
