lotsip81
Is there a way to permanently disable backlighting?
I don't like the backlighting and I never use it at all. Some roms I have tried, but found myself unable to stay on them as the unchecking "enable backlighting" feature didn't seem to work.
On Sammy roms disabling works just fine. But on most of the AOKP roms the disabling of the backlighting only works until the screen goes off. When I turn the screen back on...the lights are back on again even though the box to "enable" is not checked. I even tried to flash CM10.......just because I can
.....and the backlighting comes back on there as well.
Thanks in advance
lotsip81
.....and the backlighting comes back on there as well. Thanks in advance
lotsip81
