You could try disabling it with auto starts.
Just open it, select the after startup tab
And scroll down to Google services framework and find the one that handles system updates
(Third one in my case, may differ for you)
And disable it.
Then clear cache and reboot
In other news...We should be getting 4.2 within the next few days, I'll try to get another update zip up that doesnt check for the system apps
Sweet I'll have to check that out. I've just been editing the updater script to get rid of the checks since I have removed system apps
Never tried the ota rootkeeper one but from experience the Super Su root keeper fails. When do you plan on trying the update?
Auto run Manager is the best. Now you can decide for yourself if and when you want an ota. For me I think the bad outweighs the good right now for 4.2. Has anyone at all successfully updated without softbricking and having to start from scratch?
.Did this after receiving the nag message twice to ota update. Where does stock save otaupdate.zip
There was a similar service called update receiver service secret code left that one enabled. Might go reenable later wanna see if the nagging stops. Might reenable when I have time take a nandroid then update.
will that update nag go on forever when enabled? What is best app to keep root and restore it after an ota?Is anyone experiencing anything negative with the 4.2 update so far?
I followed the steps you provided (thank you) but I still have it every 12 hours. I did not clear any Caches this time as I did not see that step.
Could it be the Razr M is different enough so this does not work?
Any Razr M owner's with vz have any luck stopping these?
