Help Disabling annoying boost boot up sound?
I need some help disabling the annoying boost mobile boot up sound? I checked in system/media and there was no sound for it? Anyways I can't find it?
http://androidforums.com/galaxy-prevail-all-things-root/373191-boot-sound-snd-files.html
google son
If he is rooted he can use a file explorer like root explorer.
To go to
\system\media
Or was it
\system\etc\bootsound.and
Something similar to the two examples would do.
Or you can just turn down your ringer volume before you power down. That's the easiest and simplest way
Just about all of the custom ROMs have the boot sound removed. Matter of fact..... I think they all do.:D
