Motorhomer
Let's start by finding a name to describe the bit at the bottom of my S2's screen, which has four icons. These remain fixed in place even when you scroll through several screens.
Let's call it the taskbar, although that's probably not right but it will suffice.
I have deleted the Google Mail icon as I find it pretty useless as it doesn't always synch properly and display the latest mail. Using the edit function I have dragged the icon for my Dolphin browser and Gmail is listed on the Dolphin 'speed dial' and I now check Gmail using this.
So far so good. My problem is that, if I reboot, or clear my Ram, the Dolphin icon disappears and I have to go through the edit process all over again to replace it.
After editing and dragging Dolphin onto the taskbar I do press 'Save' but it makes no difference.
How can I embed an icon on my taskbar so it doesn't keep disappearing?
Thank you.
Thank you.
