dragonhart6505
Android Expert
What about app data on ext-sd (obb, data, etc)
Use flashify to flash they twrp on the link that have the requirements and flash the ROM and gapps u needWent into recovery, made a backup. Flashed the zip booted but kept rebooting in start up phase.
We know about the bug and it is being worked on. Be patientThe worst problem when I unplug my phone shuts down complete and my battery is 100% fill but in this ROM it says 0% while I'm plug in
I'm talking about video not camera![]()
Works for me
Yeah I didn't catch that one.I'm talking about video not camera
I did it under 100% is the battery statues then it shuts down completeI charged it to 100% and flashed the ROM again and that seems to have solved the battery reporting problem temporarily.
Try itYeah I didn't catch that one.
So the battery isn't register correctly so that's the situationI'll report foldermount works flawlessly for app data on ext sdcard. I assume Link2sd should work no problem as well.
CPU is locked at max and cannot be lowered.
Let my phone sit on charger (while powered on) for a few minutes unattended and started picking up battery percentage properlyproperly. Havwnt power cycled yet, but seems battery needs time to register.
Hope revised version will come fast and furious!
There's a service from stock missing to support the qpnp vm bms driver for battery I've added it back and will be included in next build.So the battery isn't register correctly so that's the situation
When will be next build,will we get notified on cm updater or we got to manually dirty flash it or do a fill wipeThere's a service from stock missing to support the qpnp vm bms driver I've added it back and will be included in next build.
Device builds are unofficial here's the link https://www.androidfilehost.com/?fid=24052804347772937 and you can dirty flash but if you have problems wipeWhen will be next build,will we get notified on cm updater or we got to manually dirty flash it or do a fill wipe
What this update about or what been fixDevice builds are unofficial here's the link https://www.androidfilehost.com/?fid=24052804347772937 and you can dirty flash but if you have problems wipe
There's a service from stock missing to support the qpnp vm bms driver for battery I've added it back and will be included in next build.What this update about or what been fix
Thanks again battery looks okay but it goes down to quickThere's a service from stock missing to support the qpnp vm bms driver for battery I've added it back and will be included in next build.
Battery acting up with the update u gave me I flash it good but now I'm not receiving no MMS or the battery isn't register at allThere's a service from stock missing to support the qpnp vm bms driver for battery I've added it back and will be included in next build.
