linsalata28
Does anyone have Pandora working on this?
I'm on 905 and it's working amazing except Pandora.
TIA for any help and replies.
Download Viper4Andriod from the playstore and install the driver, reboot and Pandora should be good to go. Choose the high quality sound also. Note: every time you update to a new build you need to reinstall the driver from Viper4A.Does anyone have Pandora working on this?
Yep it is.I'll give this a try. Thanks for the quick reply .
Edit: Is this the app from the play store?
Just want to make sure I have the right one.
Care to share your adjustments?This is the 06 build. I've themed the phone out done some personal adjustments and I am having very little bugs from it. View attachment 93565
How is video playback with default video player? Does V4A fix it so there's no demonic slowdown to audio? Does streaming video with something like TubeMate work properly?Well I added busy box pro, have Viper4A running as an audio driver, Nova launcher pro with the CM 12.1 dragon theme I use ROM toolbox pro as an all in one root app. The camera app I use with little to no bugs is found on the playstore it is called 'Camera for Andriod" by 'Andriod moblier". The bug with data and LTE can be fixed by restoring default APN setting. I flashed the 06 build over the 05 build from a nandriod backup and didn't have to mount the system and delete those files again. Still not perfect but this ROM is great.
Viper4A solved the audio driver issueHow is video playback with default video player? Does V4A fix it so there's no demonic slowdown to audio? Does streaming video with something like TubeMate work properly?
Awesome...and camcorder?Viper4A solved the audio driver issue
I have no issues with video or digital feeds. Yes this ROM still has some bugs but it is working good. I think in another build or 2 this ROM will be perfect.
Wasn't in 9/05...Camcorder is still a big?
Same here . After installing Viper4Andriod everything works amazing. I can't believe you got this working this great so fast. I'm sure there are bugs but not with anything I use.Man this rom is amazing! I flashed the 9/05 build. Camera, camcorder,lte,everything working right off soo smooth! Thanks everyone for all your hard work!
Need to allow SD write permissions. I used Foldermount which asked to patch the system for SD, rebooted and it works. Also use Titanium Backup or just make a nandroid. RTP is...a thing sometimesSame here . After installing Viper4Andriod everything works amazing. I can't believe you got this working this great so fast. I'm sure there are bugs but not with anything I use.
Well one issue I'm having is with ROM Toolbox Pro I can't get the backups to go to the SD card. Seems like I've tried everything but nothing works.
It backs up the data but not the app.
Any help with this would be great.
TIA
This is awesome. Just what I was looking for. Thank you so much.Need to allow SD write permissions. I used Foldermount which asked to patch the system for SD, rebooted and it works. Also use Titanium Backup or just make a nandroid. RTP is...a thing sometimes
