Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
OK, so here's my final statement (on the current available builds):
9/05 is the way to go! Install rom, pico-gapps, latest xposed for LP (if you use any modules) and Viper4Android, remove that cne junk and its ABSOLUTELY PERFECT! Everything works, and I mean EVERYTHING. GPS, camera/camcorder, video playback (thanks for the V4A recommendation)...its just beautiful, smooth and super stable!
If it weren't for having to install V4A to get my previous issues resolved (video playback due to audio driver issue) this ROM could be complete
i did it this way and you are correct 9/05 version works awesome no more random reboots and everything works for me.. thank you for the tip...
edit: ok only thing that does not work is MTP... other then that its a awesome and smooth rom
i found the link but i couldnt flash because it told me the wrong version. i download the recovery from OP and the rom from 09/05. are someone working with those??
Edit: Done. thanks
Same here . After installing Viper4Andriod everything works amazing. I can't believe you got this working this great so fast. I'm sure there are bugs but not with anything I use.
Well one issue I'm having is with ROM Toolbox Pro I can't get the backups to go to the SD card. Seems like I've tried everything but nothing works.
It backs up the data but not the app.
Any help with this would be great.
TIA
Quick couple questions 1:what is viper4android, 2:is there an english version, 3: what does it do? Thanks guys! On another note. 7zipper 2.0 has a great option for backing up apps to the SD card.
Sorry, not an expert, but viper4android (v4a) is an audio driver I believe. It is based off of CM DSP, and it it amazing. It helps make the quality of your music better, and is compatible with docks, Bluetooth, headphones, and phone speakers. It works really well and has many settings. It will make Pandora work on the rom. To install it, Get root uninstaller, or an app that can delete system apps, and delete audio fx. I believe someone mentioned that it's on the playstore, but I'm not sure. You'll have to look it up. Hope this helped
I sincerely apologize in advance for my ignorance guys, but could someone post or pm me a link to the correct version of xposed and v4a that I should use, if its allowed. I am with mpcs on the 9/05 cm12.1 build. I greatly appreciate it
I want to echo the sentiment on the 9/05 build, that it's bloody brilliant. It's smoother than smooth and makes the stock rom(which is pretty smooth already) seem like a bloated laggy mess. Everything works. The camera, gps, data, bluetooth, MTP data transfer, you name it. I can now fully utilize the foldermount app and can now enjoy both Real Racing 3 AND Asphalt 8.
On its audio driver bug, I get around this by using the MX player's software decoder for local video files. The youtube app doesn't seem to be affected by it nor does my cable provider's tv on the go app. Other than that, this rom is virtually perfect. Seriously, a huge thanks to hard work of Mike and Noobie. You guys are the bee knees! Thanks for putting up with us.:D
Every link worked except the xposed zip. Said the file had been moved. Thanks so much for your help @Dronic
I isntalled the ROM and its truly amazing. This is the first low-device that is getting CyanogenMod so stable.
I encontered two bugs. When I open the clock app, it crash. Also the google play services has an unkwon issue. I put here my catlog. I installed the 09/05 build and is amazing.
Hmm, I'm using the same build of CM12.1 and both the clock app and google play services work for me. Try reflashing the rom with mini gapps from here instead:http://www.androidrootz.com/2015/03/download-android-51x-lollipop-pa-gapps.html.
what is the different between them??
also what is the architecture of LG Leon MetroPCS??
Are you asking about the differences between international and US leons? To answer your second question, the Metro Leon is power by the Qualcomm's snapdragon 410(4 A53 cpu cores and Adreno 306 gpu), it has a 5mp fixed focus rear camera, a VGA front facing camera and a 1820mah battery.
Sorry I think i put my question wrong.
What is the differences between Gapps and Open Gapps?
and in the Open Gapps there is 3 version. I don't know wich is for my device. ARM, ARM64 or X86???
