mount: failed to mount /dev/block/bootdevice/by-name/system at /system: no such file or directory
unmount of /system failed: no such volume
This is the recovery you wantTried again, said Successful, but nothing installed, the only error is:
The mobile is factory reset.
Hi, i have the LG Leon MS34510e and i have two questions,
1) If necessary to have the 10b version to flash this?
2) before flash the rom the mobile is unlocked?
Regards.
1) No, you can still flash CM12.1
2) No, the phone will still be carrier locked. You'll need to get the unlock code from either your cell service provider or ebay.
Noobified said that eventually there would be two build, one for T-Mobile and one for metropcs.
As of the 06 build there is no option in the storage settings.Quick question, is there an option to unmount the sd card?
There simply isn't enough storage space in the phones internal storage for both the ROM and a full install of Gapps, but you really don't need all of those Gapps anyways. I typically strip any ROM down of apps I really don't need/use/want.so i got my gapps from the link provided, and it wouldn't let me install the full gapps package. says there isn't enough room, had to go down to mini to get it to install. what do i need to do?
Are you sure you are in the right thread or under the right andriod device. Might want to move to a different thread here.Hi everyone i dont have that phone but i think idk is the lg ls665 able to get a twrp and a rom for it? Can anyone make a twrp recovery for my phone?
I think that's the boost tribute 2 which is a Leon and has a locked bootloader.Are you sure you are in the right thread or under the right andriod device. Might want to move to a different thread here.
Too many devices with too many carriers. I hate locked bootloadersI think that's the boost tribute 2 which is a Leon and has a locked bootloader.
Yes, but with a locked bootloader. Tmo and Metro are the only LG Leon in the world with unlocked bootloaders. Yes I said world even LG international devices have locked bootloaders.So it's the same thing?
Impossible as soon as you flash TWRP you will get a secure boot error.Just in a curiosity can i flash this?
