Just wanted to see if all the major bugs we're work out yet . might flash my phone in a few .
okay all done. I got the 9/6Most bugs are fixed. If you want to flash a build I would suggest either the 9/5 or the 9/6. I'm rocking the 9/5 build and it's pretty awesome so far.
We need cigarette forgiveness when swpipingDoes the latest cm12 for this phone still having awkard reboots ??
Not that I can tell . haven't had to reboot once yetDoes the latest cm12 for this phone still having awkard reboots ??
Whats ciggarette forgiveness?We need cigarette forgiveness when swpiping
I think I was high sorry won't happen again.Whats ciggarette forgiveness?
Don't harsh our buzz maaaaan*in a stern voice* Young man that stuff kills brain cells don't cha know? Haven't you seen the movie Refer Madness? Kids these days!![]()
I see people are reporting it still I'd just do 05 build and delete the CNE shitCan anyone tell me if theres still reboots in latest build??
9/05 here, never a single rebootCan anyone tell me if theres still reboots in latest build??
Is there a specific version of NitroX we should use?i tried the prime or something & had alot of troubles manipulating options in the terminal. And whats ram expander?If multitasking is your thing, then you might wanna think about SWAP. I bought RAM Expander to not have to completely reformat my SD but there's free alternatives out there. You can also use NitroX. Its a flashable zip configurable with Terminal Emulator aimed specifically at keeping your phone smooth.
You'll always get some lag while underclocking, its just the lay of the land bro.
I use Optimus Optimus 3.0 beta 2. In terminal, just get su permissions and type menu, then do what you'd like from the selections. Its pretty complex, but very user friendly IMO so long as you know what your enabling/disabling/modifying. The xda page describes everything in detail too, so when you get a minute read through it.Is there a specific version of NitroX we should use?i tried the prime or something & had alot of troubles manipulating options in the terminal. And whats ram expander?
I tried to use that version,however i get all kinds of file system errors from the init d directory... Then nothing changes.for example,tried to change the force profile to balanced and it throws me read only filesystem.idk.if you can PM me with suggestions thatd be awesome,i dont want to take this thread off topic.sorry if i have.I use Optimus Optimus 3.0 beta 2. In terminal, just get su permissions and type menu, then do what you'd like from the selections. Its pretty complex, but very user friendly IMO so long as you know what your enabling/disabling/modifying. The xda page describes everything in detail too, so when you get a minute read through it.
Ram Expander is a SWAP manager. You can either format a partition designated for SWAP or set up a file without a SWAP directly to your ext. SD and it works just as well. Wouldn't really bother setting it higher than 1024 mb as it wouldn't do too much. Great for multitasking!
Hope that helps
Did you delete everything in your init.d folder? Every file needs to be deleted, then flash the zipI tried to use that version,however i get all kinds of file system errors from the init d directory... Then nothing changes.for example,tried to change the force profile to balanced and it throws me read only filesystem.idk.if you can PM me with suggestions thatd be awesome,i dont want to take this thread off topic.sorry if i have.
Lol, oh yeah. You need to make /system r/w before anything sticks. Use a root explorer or ooption 18 in the menuI tried to use that version,however i get all kinds of file system errors from the init d directory... Then nothing changes.for example,tried to change the force profile to balanced and it throws me read only filesystem.idk.if you can PM me with suggestions thatd be awesome,i dont want to take this thread off topic.sorry if i have.
I've found no issues with a clean install. I always just restore data with nandroid, I hate dirty flashingIs anybody else having any issues changing the brightness in build 9/05? Whether I put it at the lowest or the max it doesn't change at all and just stays bright. I've been using a 3rd party app to control it in the meantime. Could it be a problem with how it was installed? Other then that everything is working great. Few reboots, gonna try and logcat those to see whats causing it.
Well you always have the option to backup these partions thru recovery:It was a clean install. I just finished backing up all my apps with Titanium so i'm gonna do a complete wipe and re-install and hope it fixes all issues. I've never made a selective nandroid backup, is it possible to only backup certain things, or is it the whole system?
