Monster212
I get random reboots once in awhile with the 05 build, once a day at least... But still a great rom...
I flashed this on the 12d version, no problems. I am able to go back and forth between this ROM and stock no trouble at all.Many questions 1 has anyone flashed this on 10d 2 can I use this as my daily driver 3 when I go back to stock will my wifi/usb otions be obsolete like my old phone 4 what are all the bugs in the latest build I'm really debating about getting this so it'll be very helpful for a response on all of these questions thanks
So no camera gps lte probes??????? And can the broken wifi and usb thing on my old phone be because i restored the Efs Partition through twrp just trying to prevent this from happening againI flashed this on the 12d version, no problems. I am able to go back and forth between this ROM and stock no trouble at all.
Another post said when restoring stock backup, after you restore it wipe cache and dalvik then fix permissions. I haven't been able to test it since I deleted my backup.So no camera gps lte probes??????? And can the broken wifi and usb thing on my old phone be because i restored the Efs Partition through twrp just trying to prevent this from happening again
You can do it from 10b to 10e. After you root on 10e click the build number a bunch and turn on oem unlock in developer options then the blue twrp and you are there.so if I download 10d I can get cm 12.1???
You restored stock from CM? What build did you come from and did you use the same TWRP version to backup and restore? Example: backed up with blue and restored with blue. Did you have any problems?i restored back to stock last night and all is good.
edit: had to check but im on 10d
AFAIK you cant flash this on 10e. I had to downgrade from 10e to 10d using the LG Flash tool, install the blue twrp in the OP using Flashify, enable dev options, OEM unlock, reboot to recovery, make a backup of stock ROM, wipe, and then flash Cm12.1 9/05 build and gapps. Then mount system in blue twrp and delete all the CNE stuff using TWRP's file manager. I still get a reboot about once a day, and every time I turn on hotspot.Just gonna flash this on 10E
Hotspot works for me but crashes when I turn it off. I took a catlog on verbose mode for anyone interested in seeing what the problem may be. Build is 09/05
https://drive.google.com/file/d/0B0vhPvlniTD2anYzQUpuSVZvYjQ/view?usp=sharing
"09-25 08:52:43.526" search for that to find where i go into settings to get started on recreating.
Camera doesn't work, using GPS reboots the phone.Why does everyone keep saying build 09/05 there is a 09/06 build whats so wrong with that one
they work for meCamera doesn't work, using GPS reboots the phone.
Its the only link on the first post..where i can find the 09/06 build???
