Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
Welllll.....I've been making progress with installing the ROMs just fine, but once i reboot it gets caught in a softbrick, literally the roms install correctly with no problems, then i install the gapps package but it doesn't seem to work, ig i just need to find a phone that has the closest specs to this one and try to port from that
Keep up the good work would love to see something other than cm on this phone tho ;) haven't tried it cm yet waiting to see if lg will update this phone to android marshmellow
OK, I'll begin porting the rom again, does anyone know of a phone that has custom roms for it, thats related closely to this one? I've been porting roms from the Moto E 2015, because its so close in specs i believe
Only phone I can think of is the Samsung Galaxy avant and the only thing I found was a touch wiz lollipop rom ;)
Could you also look into making it work with the h320 model? I'm willing to get more involved in the development and testing process if you need so.
OK, thanks guys, u definitely give Me the inspiration, is the avant touchwize ROM worth it? And I can try to for the h320, if I could get the build prop for it. And after in done doing these ports I'll have them available for download to try and help make logcats to solve the boot loop issue
What do you mean by more stable? Less reboots?
On the 0905 build I was getting multiple reboots a day. On 0906 I've gotten one reboot over the course of 48 hours. Battery life seems to be more stable and on 0905 the charging was pretty slow. Now it charges like a normal phone. I also fixed my APN settings and I no longer have random dropped LTE connection. But that could be more related to the 0906 build as opposed to APN though I think it was APN settings. Overall I would recommend 0906 build. All I did was backup and then I dirty flashed it over 0905 and I didn't run into any issues.
And gps works
Just noticed your posts. Yes I have no issues with the battery, camera, messages or GPS. I have 0 issues as of yet. Zoomed in to hide location in screenshot. But I've used uber twice with no issues.
So I've ported pacman again and tried installing and rebooting, same issue=A soft brick. I've tried getting a logcat for this but either I'm not really good at it or I'm just doing it wrong, if anyone else wants to help with this that would be awesome, I'll upload it and you'll be able to download the pacman rom and get a logcat, and then maybe we can fix this issue
Why when i do adb logcat does it say
/sbin/sh: exec: line 1: logcat: not found
Nvm, didn't mount the system but now i get a different error
logcat read failure: No such file or directory
Ik its there in /system/bin/logcat but i dont know why it doesn't work
