It's the third from last post on page 52. Well at least in mobile it is. Found it in under 2 minutesSomeone give me the link to the 0905 build
What do you mean 07 build i only see 06I see 07 build came out anyone testing it yet . if so do you have info on ways working and not .
Doesn't exist, the build he noticed was actually from julyWhat do you mean 07 build i only see 06
I found it but it's saying error 404 not found can someone give me another link to the 0905 build plz????????It's the third from last post on page 52. Well at least in mobile it is. Found it in under 2 minutes
How's it been going so farActually I am, been trying to port the pacman ROM, it install in the twrp recovery but deletes the system partition, I've tried to convert Bliss, pacman, liquid smooth, will try carbon next
The hotspot is a known issue. As for myself I don't have any problems with Google now. Get a catlog and post it here.Hey guys, havin a strange issue. Every time I turn on hotspot, once I connect my PC, my phone reboots on CM12.1 9/05 build. I have deleted the CNE files, and the ROM works great except this issue and Google Now. Everytime I use Google app it reboots my phone before answering my question. Any advice or help would be greatly appreciated. Thanks guys!!
Welllll.....I've been making progress with installing the ROMs just fine, but once i reboot it gets caught in a softbrick, literally the roms install correctly with no problems, then i install the gapps package but it doesn't seem to work, ig i just need to find a phone that has the closest specs to this one and try to port from thatHow's it been going so far
Logcat?Welllll.....I've been making progress with installing the ROMs just fine, but once i reboot it gets caught in a softbrick, literally the roms install correctly with no problems, then i install the gapps package but it doesn't seem to work, ig i just need to find a phone that has the closest specs to this one and try to port from that
What do u mean?Logcat?
Do you have the pacman ported ROM in order to fix bootscreen loop you have to logcat and fix problemWhat do u mean?
I've deleted it, but i can redo this easily and give u a copy to try if you'd like as well, an another question, how would i be able to logcat if i cant even boot into the os? is there something in TWRP that im missing?Do you have the pacman ported ROM in order to fix bootscreen loop you have to logcat and fix problem
Are you getting any issues with 0906 build? Random restarts? Network losing LTE connection till you restart the APN settings? Any issues at all?And man they're are a lot of ppl posting issues, lol I like the 06 build, it's fast and reliable, and I get to theme the whole phone like never b4, so to me this is really awesome, never got a chance to use CM back then because none of my phones supported it and now I'm just greatful i finally got it, so thanks to all the ppl who've helped the LEPT make this happen for our phone that we each use in this thread and our daily lives![]()
I dont get random reboots unless using the hotspot, and messing up.and its very rare that my metro data drops an disconnects till i reset the APN, camera is fine, but the only problem is that i cant do all i want when installing linux on my phone via linux deployAre you getting any issues with 0906 build? Random restarts? Network losing LTE connection till you restart the APN settings? Any issues at all?
Also if anyone has the LTE connection dropping till you reset APN try changing your APN settings for MetroPCS LTE (fast.metropcs.com) open that up and change the following settings:
APN type: default,mms,suplex,hipri
APN Protocol: IPv6
MVNO type: GID
MVNO value: 6d38
Then switch to that APN and I haven't had connection drops in days now. For some reason my phone was using the fast.t-mobile.com APN and my connection would drop for a while and if I changed it to a different APN it would revert back. But ever since I put in the correct settings for fast.metropcs.com it no longer switches over and no longer drops. Just random reboots multiple times a day now.
Agreed I'm going to make sure i definitely do my research b4 buying a new phone, I'm definitely up to having root and this type of custom ROM installed on my phone foreverI agree. The 9/05 build has been my daily driver for two weeks now and it's been awesome. I can see why CyanogenMOD has been the top rom choice for many android users. It's going to be hard to buy any phone in the future that doesn't have a port of CM.
Looks like this is the new accepted method to obtain root on 10e and 10f: http://androidforums.com/threads/le...-10d-10e-ms345-h345-no-kingroot.938062/unreadAnd also, my friend has a 10e version of this phone, i unlocked his oem already by enabling developer settings but now i need help rooting it, any adivce? I tried doing it the same way i've done mine, which is use king root, also tried installing kingroot using vroot, how would i go about doing this?
Logcat via ADBI've deleted it, but i can redo this easily and give u a copy to try if you'd like as well, an another question, how would i be able to logcat if i cant even boot into the os? is there something in TWRP that im missing?
