Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
Ya I know but TWRP manager says I already have blue one installed. So I should check out websight and see if I can download IMG that way? cause its acktin like it won't let me replace it
Download the image file from their website and flash it using Flashify. It should work, remember to make a current nandriod backup of CM 12.1 and remember to go back to your stock recovery image before flashing the yellow version. You will need to go back to the blue TWRP before going back to CM 12.1- That should take care of your issue.
have no pc. I've always done this with TWRP sooooo easy in TWRP. A parted is very complicated and so is ROESOFTS Partition tool apk. huh looks like I'm not getting partitioned till I get around another phone with TWRP with partition option. Soooo dumb our ver dnt have it.
I just thought of this ROM toolbox has a function within the app that partitions ex-sd cards. I have the pro version apk available if you want to check that out.
Just extra memory somthin to tweak around with. I use to use warranty voiders SD hacks. Didn't realize it was exclusively for the F6. Using Apps2SD at the moment it has an easy to use partition tool within the apk. foldermount not to mention the uninstall apps works where even Titanium and Romtoolbox won't. But ya I'm just a modifying! lol
P.S. my bad are you saying I can open a partition for init.d scripting and whatnot? Just asking cause if so I'm game for ANY thing to learn/new tweaks etc. Thanks for enquiring by the way bro [emoji16]
Just wanted to say thank you. Amazing ROM . Works flawlessly. I haven't found any bugs. GPS and camera work perfectly. You should remove camera and GPS from the not working section of the op. And I came from stock E.
Ya there's been a few modified builds on CM 12.1 for the Leon. It is a nice ROM I agree but CM on Lollipop seams to be a bit Loopy, as in bootloopy. We had a sweet lil deodexed ROM that would have been ready for download but my boys Laptop broke down on em' But sooner or later.
Exactly. Sooner or Later! That ROM I was also working on showed us KR's newest hidden files to remove and be added to a permanent removal list for future references. Not removing everything can brick a device the way KR did that deal..
