Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
Read through entire thread and it doesn't mention if it needs to be flashed from int or ext SD? Wanna flash Nitro X then make a quick nandroid so I can link bcrichster the CM boot IMG he needs.
No no, My bad I wasnt saying no ext int SD about init.d bro. I was talking about a members issue with not having an external SD card at theyre disposal.
Flashify is going to route you into TWRP anyway. Is you're TWRP color yellow or blue? And try rashr flash app off playstore. I like it better then flashify myself and its easy to use with Kingo and won't deny root beacause of the non recognition of SU. But ya what color is your TWRP plz?
Do I need to use Flashify to flash the rom or do I use TWRP?
I tried to flash it twice using TWRP but it gave me some error that it couldn't apply.
I'm so confused...but it doesn't matter if you use internal or external to flash NitroX in TWRP. Its just a zip, then configure it in Terminal
Has anyone returned to stock on 10F? Just curious about any changes because I downloaded the kernel to make a diff of changes. The only changes made was deleting code of global g4 stylus. Just wondering is there any stock changes I should be aware of so I can download the kdz and pull the latest blobs.
I did with lg flash tool no problems at all stock still works
Plus no changes I see just stability and bug fixes
Can you fix the bug where the WiFi or cell service drops randomly?
and sooo sorry for bugging you but when cm 13 aka Android m releases do you plan on porting it to this device I would love to have Google now on tap
Change fast.metropcs.com APN settings to these then switch to it. It worked for me.
I knoticed after typing in SU then Mode within terninal and after the different options come up and I chose say number 4, That it would tell me to reboot asap when done. Are we only allowed one script at a time? As in type in the number for what script you wanna run then roobot. Then go back into terminal and redo, then pic the next script you want to run reboot then the next script etc. etc & on & on or?
Nah, you can do more than one and reboot when your satisfied
Noobified, Mike Honcho - Thank you for all your hard work on this build. My Nexus 5 WiFi died last week, so I picked this phone up for $29. Found how to root on XDA, LG Flash Tool back to 10d firmware, kingroot, replace with SuperSu, then found this thread, followed directions, and voila - buttery smooth CyanogenMod.
For anyone having problems -READ! I have read over 100 pages of forums over the past week in regards to rooting 2 different phones, and installing this custom ROM, and nothing makes me more upset than reading a question that is answered in the FIRST POST. I'm still a noob, but I read and respect what others have done before me. Thanks again, LEPT, and I look forward to seeing the next build.
Anybody have a link to the yellow TWRP IMG? I wanna switch to yellow to partition my SD card real quick then switch back. Yellow use to be at beginning of thread but must have been switched out. Anybody know the deal on this plz?
