Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
Has anyone tried the new C-Apps package yet? I flashed it and it works just fine, I especially like the new theme store
Is there anyway to update the stock via ota? They released a new system update and I can't update the stock ROM because it reboots into twrp each time. The only way I've found is if I enabled the "update cyanogen recovery" option in the development settings, but that's not available in the stock ROM, and the update isn't for cm12 so I can't do anything unless anyone here knows different. Any ideas?
Yes. You need 100% stock everything. Not deodexed, not debloated, NO ROOT, and stock recovery. Flash stock unmodified ROM then flash stock recovery & reboot.
Dam, OK looks like I'm hit man but thanks for responding to me quickly, I dont have the stock recovery anymore, does anybody have it? It would be greatly appreciated
If you use the unbrick guide it will flash your phone back to stock. Including stock recovery.
Or use flashify
Or use adb
Put the IMG on the root of your sdcard and type
Adb shell
su
dd if=/storage/emulated/legacy/recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery
0906 is the best yet if I am not mistaken? Curious as to if there is a fix for Pandora not working...
For Pandora to work on this rom, I got V4A(viper4android). Its on Google play. Just download then open the app & go thru the setup & choose which of the types you want. May ask to reboot here, if so, do it. After that, enable it by opening the app & checking the little box that says "enable" at the top under where it says master power. Then reboot your phone. After that, all thats left is to either freeze or uninstall the CM stock audio driver & reboot again. To freeze or uninstall it, i recommend titan backup as its been reliable to me & the majority the rooting community. Pandora won't work unless u freeze or uninstall that app & have V4a enabled. Once you're done, pandora should work right as rain. This worked for me & i hope it works for you too. Any questions feel free to ask.
Has anyone noticed that SQLITE3 is not installed on this version. I couldn't optimize my databases using SDMaid. I wonder if there is going to be a new version.
In order to flash the ROM do I have to have a blue twrp recovery boot because mine looks orangeorange if it does matter how do I change it?
Has anyone found a work around to fix the GPS on this rom. Also my WiFi hotspot doesn't seem to be working correctly. Anyone else experiencing this problem?
