antonioblee1
No unlock method on this rom .have to go to stockyes it's like i said, there is any kind of unlock method with this rom? thanks
No I hear ya bro. & I had some higher hopes myself for the development on & for this device buuuuuut I myself feel the Leon is kind of a headache in which battery life is just WAAAAAY!!! to scarce to deal with. Its not worth owning in my opinion. Not to mention thus far LP custom ROMs (atleast as far as this device is concerned) are just to "bootloopy" & again LG did a horrible job on its battery life. Androids I ran 5 years ago had better batt life. But I totally understand you're frustration bro!!!! I'm on you're side here all the wayNever said it was easy buddy don't put words in my mouth sorry I want to not let the phone just die and try and get it to a dev whos not as busy as honcho of course I appreciate honcho too for alls he's done but that don't mean just cause he's done the phones done
Where are you getting all this bad battery life? i get 4-5 hours SOT easily, unless you have brightness on max it shouldnt be that badNo I hear ya bro. & I had some higher hopes myself for the development on & for this device buuuuuut I myself feel the Leon is kind of a headache in which battery life is just WAAAAAY!!! to scarce to deal with. Its not worth owning in my opinion. Not to mention thus far LP custom ROMs (atleast as far as this device is concerned) are just to "bootloopy" & again LG did a horrible job on its battery life. Androids I ran 5 years ago had better batt life. But I totally understand you're frustration bro!!!! I'm on you're side here all the way
Otg does not work on lg Leon . not even stock .Does anyone know if USB otg would work on this device running cm12.1?
took me a little longer to get to this. so when i did it again it boot loops 3 times then on the fourth try it goes to recovery.
Yep. Installed 906 and tried to flash 905 kernel. Resulted in 3 lg logo flashes followed by twrp boot. Went back to 906 kernel and it booted. Now I'm completely on 905 running fine.905 Kernel?
No I'm just saying I didn't know/think this device had a custom kernel.Yep. Installed 906 and tried to flash 905 kernel. Resulted in 3 lg logo flashes followed by twrp boot. Went back to 906 kernel and it booted. Now I'm completely on 905 running fine.
Oh!! No, not a custom kernel...just the kernel compiled with the 905 build running on the 906 build. Others have reported success.No I'm just saying I didn't know/think this device had a custom kernel.
GotchaOh!! No, not a custom kernel...just the kernel compiled with the 905 build running on the 906 build. Others have reported success.
did you dirty flash or clean flash? is cam working?Gotcha
Full wipe, I came off stock ROM. And cam works like a charm!!!did you dirty flash or clean flash? is cam working?
I started from stock 10f. Went to 905 build. Can works. Video only works if going to internal storage. Trying to go to SD card results in a couldn't connect to camera error.did you dirty flash or clean flash? is cam working?
THANK YOU !!!!!!!!!!!! got camcorder working been trying to figure this out for days thank you so muchI started from stock 10f. Went to 905 build. Can works. Video only works if going to internal storage. Trying to go to SD card results in a couldn't connect to camera error.
GPS works for me maybe one of of every 8 tries. Otherwise it soft reboots.
Neither camcorder or GPS worked for me on the 906 build.
When installing the 905 build, before you reboot (while still in TWRP) make sure to Mount system, navigate to there and delete the files mentioned on page 20(or there about)
You're welcome!! I should really set up my laptop to try and help fix these bugs!!! Any pointers on where to go to get my machine set up properly? (Too lazy to look up at the moment.THANK YOU !!!!!!!!!!!! got camcorder working been trying to figure this out for days thank you so much
acctualy yes i do know a few download the tree and model info from original post download andriod kitchen, sdk tools java something google how to creat roms most of the sites have programs for flashable zips and a kdz exstracter and go from there thats all i know sir
I have the LG RISIO (LeonLTE sister phone) and was wondering if someone here would help get a working recovery for the Risio and Cyanogenmod....I have root with Kingroot & Super-sume.Thanks! I did grab the tree the other day. I'll have to either get a Linux VM set up, or (more likely) dual boot my win10 with Ubuntu. Found lots of good info on CM's website. I'll have to go find one of those kdz extractors!
Edit: got Ubuntu dual booting with Windows 10. Decided to grab AOSP from Google to see if I could get it to compile. Then I'll grab the cm12.1 tree for the Leon.
Also got the 10f kdz from lg. Haven't extracted it yet.
