harrison77
So If I have lg ms34510d I cant install this
Did but keeps rebooting at select language?Actually, it works. You just need to root it and flash the recovery.
I'd do a full wipe and start over!Did but keeps rebooting at select language?
Thank You I got it working but I would like to try that anyway didn't know it existed until you informed me You're Reply is appreciated, it's people like you that make this forum better I'll make sure its notedI'd do a full wipe and start over!
In petty sure the 10d at the end is just your firmware version.
If this one doesn't work out for you, you might want to go try out the xenonHD one. Very similar ROMs. And I'm pretty sure that one has a bit more continued dev going on for it.
nobodys answered right? i have an lg70 d321 and it seems the same scenario w the risio. roms and recovery for "sister" phones (the lg 70 m253) that will brick my d321 and apparently the stuff that works on the leon wont for risio. no roms, no recoverys, i dont get it. i think i even saw custom stuff for throwaway tracphones. i wish i knew how to design rpms and recovery. id check the device list on these forums and compare to manufacturer list,(this forom, no risio) and strictly design for the misfits. PLEASE SOMEONE DO SOMETHING AWSOME FOR THE D321 AND H343!I have the LG RISIO (LeonLTE sister phone) and was wondering if someone here would help get a working recovery for the Risio and Cyanogenmod....I have root with Kingroot & Super-sume.
I feel your pain man...lol. These I have the Risio....its a pretty good phone but wtf about bloat?? Need a custom Recovery & Rom to get rid of it and get slim. I would "donate" for some development on this .nobodys answered right? i have an lg70 d321 and it seems the same scenario w the risio. roms and recovery for "sister" phones (the lg 70 m253) that will brick my d321 and apparently the stuff that works on the leon wont for risio. no roms, no recoverys, i dont get it. i think i even saw custom stuff for throwaway tracphones. i wish i knew how to design rpms and recovery. id check the device list on these forums and compare to manufacturer list,(this forom, no risio) and strictly design for the misfits. PLEASE SOMEONE DO SOMETHING AWSOME FOR THE D321 AND H343!
That's not a bad idea...ha! We should build a start up that contracts Rom and recovery development. (sigh) if only I hadn't ruined my credit as young stupid kid in the NAVY. And not finishing my business degree. And the jailtime....
Damn...Thought I was the only one lol...You would think there wouldnt be a whole lot different in the Leon/Rosio Roms to be able to get something going....HEY ANDROID COMMUNITY...not everyone can afford upper-end phones and plans...some have to work with what is avaliable...so with that understanding can we get a little help with this??I feel your pain man...lol. These I have the Risio....its a pretty good phone but wtf about bloat?? Need a custom Recovery & Rom to get rid of it and get slim. I would "donate" for some development on this .
Well I'm always sure a custom ROM is a better route to follow if you're going for bloat free, but as long as you're rooted you can just use titanium backup, SD maid, root uninstaller, or a brick. The last method was how I ended up using the warranty. Don't use that method.I feel your pain man...lol. These I have the Risio....its a pretty good phone but wtf about bloat?? Need a custom Recovery & Rom to get rid of it and get slim. I would "donate" for some development on this .
HaHa...yeah I cant afford a brick but I'd get another phone if I could. I learned from past experiences not to try anything without a good working recovery installed...I'd be happy with just that for right now..Well I'm always sure a custom ROM is a better route to follow if you're going for bloat free, but as long as you're rooted you can just use titanium backup, SD maid, root uninstaller, or a brick. The last method was how I ended up using the warranty. Don't use that method.
WiFi tethering non native doesn't seem to work just brings up native tethering? Anybody had this issue?HaHa...yeah I cant afford a brick but I'd get another phone if I could. I learned from past experiences not to try anything without a good working recovery installed...I'd be happy with just that for right now..
Can someone list the bugs
For those of you who are unable to use video recording, I found that downloading powercam from the play store is a fairly simple work around. Just download the video extension through the app.Everything except for GPS works flawlessly in build 0905. I don't know what you changed on 0906 but video recording is broken on it. I have stayed on 0905 since it came out. IMO you should forget about 0906 altogether and focus on fixing GPS on 0905.
For those of you who are unable to use video recording, I found that downloading powercam from the play store is a fairly simple work around. Just download the video extension through the app. I'm on Cm12.1 9/06 build.
Try going into your phones SETTINGS....then DEVELOPER OPTIONS....then ENABLE OEM UNLOCK..how i unlock the bootloader ?
Go to Setings .About Phone. Software Info. Tap build number 5 times. The Developer Options tab will be above the About Phone tab.this phone does not have developer options in settings :/
thanks =)Go to setings .about phone.software info. Tap build number 5 times.
