Root Display Problems...
sk8rgeek
When i turn my screen on for anything the last 2 days, it doesnt come on right away, takes a minute. After phone calls, it doesnt come back at all, have to remove battery.
Any Ideas?
Try using a cache cleaner to clean out the phone. I suggest using SD Maid pro but they do have a free version. It cleans out a lot.
Yeah restore a back up. Also bring down the GHz on the max oc. A lot think oh higher the GHz the faster the phone. Which in theory yes. But it can also have reverse effects and cause lag such as response time at wake up, unlock, apps opening, etc etc.
Haha yeah i know. Im not dummy though. I keep mine running at 768MHz most of the time. Also i have the profiles set up for underclock except during phone calls, i have set to 1024MHz max. Only reason to run past 1.2GHz doing things other than browsing the web is pointless lol. I think it might have something to do with trying to get stable benchmarks at 2.1GHz. Might have slightly "aged" my processor lmao
whats your min set too? if its below 245Mhz that could be causing it.
I know this sounds funny but it happens ( I see it on a daily basis)
on the top left corner of you phone you have two sensors;
-Light sensor
-prox sensor
Do you have a case that covers them or a sticker (again I know, sounds silly but I've seen it many times) or a screen protector with bubbles?
IF so make sure it's not covering the prox sensor. What you mentioned with the 'making calls and the screen not coming back' the prox sensor controls that.
and if it's covered you will experience the issue.
and if neither of those are the issue you might just have an lcd screen fading out on you ;( (wrnty exchange if you can install everything back to stock).
