Help Does anyone have Auto Brightness still enabled?
Morat
I've had to turn mine off, it was consistently way too dark. Is there a way to adjust the threshold?
thanks,
Morat
Ooh, thanks - that looks pretty handy. Strange that there must be such a variation in brightness....
I'll see what I can do with it :)
Morat
me too. i find that setting it at around 30% is fine for me for the entire day :D i rarely change it, except at night when im using it in almost darkness, in which case i turn on Screen filter :D
And strangely enough, I've kept auto brightness enabled on my replacement handset because it keeps the screen at a decent level. It looks there can be some variation.
I actually like the auto brightness feature on the SGSII.
Much better than on some of the phones I've owned. Compensates well for all light conditions and in my tests, it did not appear to drain my battery.
I'm running on auto but I have had to over-ride the setting to increase the brightness a little mainly when outside. So I stuck the widget for it on the home screen.
