Does anyone know of a CDMA\LTE Widget or toggle for the Main screen??
swc2001
Android Expert
Well I am looking for an easy way to toggle on off the CDMA\LTE to CDMA only for the front screen so I dont have to go through all the settings poo and what not. The reason is I have 4g away from home and like to use it.... but When I am at home I toggle it to CDMA only because I am on the bubble of 3g 4g so it tries to switch back and forth thus killing the battery quicker and making it frusterating getting data. Since I went to the .901 update things are awesome but I still need to click it over to CDMA. So I was just wondering if such a toggle of some kind existed or not.
Gimme da easy button baby!!
As always I sure do appreciate it guys.
I'm pretty sure there still isn't a widget that will automatically toggle you between 3g and 4g for the Bionic. LTE Switch is the closest thing that I've found, it's good enough for now.
Well originally it took you 6 clicks.
Now it takes 3 clicks with LTE switcher which is better.
But IM LAZY and I want the FM button. Freakin Magic Button. LOL
For now I will trudge thru with LTE switcher.
Thanks Bro.
Although could someone modify Team BAMFS widget to work for the Bionic?
http://www.droid-lif...thanks-to-bamf/
