LG F6 forum has a thread about externalSD2Internal script. I guess the script will mount the external (real) SD card as internal (fake) SD card. But L6 is Android 4.1. Will this script work on our Android 4.4 L70?
To (sort of) answer my own question, yes, the internal fake SD can be mounted to external real SD with no problems. I am using stock ROM, no CWM, and I did not uninstall any system apps (I did freeze some of them).
I have no idea about LG Motion. But on L70, folders under internal SD can be bind mounted to external SD (foldermount app works great). So far I only mounted a couple of folders. I have not tried my luck to mount the whole internal SD card as I already have enough free space.
