Tried it, drivers are installed and the phone shows up in the list but as an unknown phone type. When I select it and try to run service programming I get an "online connection error" and it doesn't connect.
Since posting this I did get it to work, it just has to be the right version. 2.7 Build 374 works, although maybe not 100% for all parameters. I've used it to change PRL's.
got it to work. i used qpst 2.7 build 374
1) dial ##626*
2) DO NOT put your msl instead put 587846
3) Select NAM programming
4) Stay There
5) Start QPST
6) Add the port [should be the only one you can add]
I changed my ip to simple only by going to the m.ip tab
and i changed my PRL by going to the roam tab
I'm using 9033 now, which is supposed to let us roam onto sprints 3g network [I think] lol
100% safe ???
hey johnny I think im gonna need that step by step so I can flash 9033
I managed to get QPST to recognize my phone but when I try to read from the phone, it says that the service programming code is incorrect. I tried both the default 000000 and 587846 and neither of them work.
I got 587846 from johnnyolivares' small tutorial. I tried the SPC finder from whiterabbit.org/android but I can't seem to find my MEID or ESN in the phone settings.How did you get the second code? Did you use MEID Converter? If not download that app and use it to generate the code, it should work.
Same here![]()
